Hi all:
I need to convert some of my dvd's to avi (divx).
I'm trying to follow the following guide https://forum.videohelp.com/viewtopic.php?p=1271288#1271288
The results are : or an incomplete avi file (only part of the movie)
Or the message : could not open E:video_TS:name of the movie.avi
Here's a discription of all my steps:
1-I Open file and double click on the 1st VOB file
on the source I can see the information about the file duration: 00:00:08,1 bitrate 1242 etc... etc....
2 Target: I select = mpeg4
3-format: PAL
4= bitrate: changed according to movie inf. 1242
5-On video = 0
audio= 1
Then I start adding all the other VOB files making, Batch + Add to batch.(add current command)
When all the files are added I select batch + run batch the encoding starts, but I can see the information on the DOS box that time is only 44,16 when it should be more than 2 hours !!
What am I doing wrong ??
I have only 1 doubt regarding the guide:
I dont have on the menu the option : ADD TO BATCH !! I have instead "ADD CURRENT COMMAND" dont know if it's the same !!. Maybe this is the problem ??? !!!
Someone van help me please ??.
hilario.
Results 1 to 10 of 10
Hi
Altough i dont have a solution for your problem, can you tell me if gui4ffmpeg uses the divx5/6 codec as i think that tool uses the divx4 codec.
if you're looking for simplicity theres some other tools outhere, i use avi.Net but theres AutoGK and DRdivx2.
That program looks a bit outdatedI love it when a plan comes together! -
Humm Ricardouk:
I'm afraid I dont know the answer to yr question.
But I will follow yr suggestions and will come back.
thank you very much.
hilario. -
you can use dvd decrypter in ifo mode aswell.Originally Posted by manono
i think you should see if you're converting to divx4 as quality is lower than using xvid1.1 or divx 5 or 6.
open one of your converted files with gspot and post the screnshot here if you canI love it when a plan comes together! -
OK Ricardo:
(eu nem reparei que eras português)
Let's forget for a while pgcdemux.
I used now DVD decrypter, togerther with autoGordian.
My problem now is :
When I select the files I want to convert to avi on AutoGK ( afer using DVD Dcrypter) I still have
3 VOB files !!! which ones do I have to select ???
This is my problem now.
Obrigado desde já pela tua ajuda . (e paciencia)
hilario. -
Hi, Autogk doesnt really need to have all vob files in one, just select the ifo file. i only suggested to use pgcdemux because your avi files with ffmpeg were only partially converted
read this guide in portuguese
http://www.autogk.me.uk/modules.php?name=Tutorial
hope that helpsI love it when a plan comes together! -
Tks Ricardo:
Its done:
And its perfect.
I will use this system from now on.
hilario.
EDIT: I have only one doubt: Which is the right IFO file that I have to select ??
As for an example another DVD to be converted has the following IFO files:
VTS_01_0.IFO (58 KB)
VIDEO_TS.IFO (12 KB)
VTS_01_0.IFO
this might vary if you're ripping episodic dvds, it might be VTS_02 for the second episode and so on.
When ripping with DVDdecrypter click on EDIT>>>>SELECT MAIN MOVIE ONLY and it will copy just the right ifo file
(Boa sorte nessas conversões
Converting DivX to DVD, along with subtitles?
By guy24s in forum Video ConversionReplies: 2Last Post: 21st Jul 2011, 20:00 -
Converting my DVD's to DivX
By noob2 in forum Video ConversionReplies: 2Last Post: 12th Jul 2009, 20:04 -
Converting Divx to DVD format
By bpatters69 in forum Authoring (DVD)Replies: 8Last Post: 14th Jun 2009, 14:48 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Problems converting DIVX files to DVD
By Jack_Dante in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2007, 13:12
