Hi all,
I have two clips at 720x576 60 fps PNG.
What type are these files ?
How can i convert them to 720x576 25 fps ?
(or can i just use them in a PAL DV project, 25fps ?)
Thank you
Open the sequence (assuming they're nicely numbered) in VirtualDubMod. Select Video -> Frame Rate. In the top portion of the dialog select "change to [60] frames per second" to let VirtualDub know the frame rate of the image sequence. In the middle box select "convert to [25] fps". Save or frameserve. This will be a little jerky. If you have matching audio it will not have to be adjusted.
Another option is to speed up the source frame rate to 62.5 then convert to 25 fps. That will be a little smoother but will play 4 percent faster. Audio will have to be similarly adjusted. -
I'm confused. I thought PNG files were only single image. Are you saying these PNGs play as video? What do you play them in? Can you check them with GSpot?
Buy My Books -
I assumed he meant he had a bunch of PNG files that constituted a video. VirtualDub can open a numbered sequence of image files as if they were a video file. It can also save a video file as a numbered sequence of images.
I guess it's possible he has an AVI (or other container) that uses PNG as the video codec.
<edit>
Oh yeah, here a lossless PNG video codec:
http://www.free-codecs.com/download/CorePNG.htm
I'll have to try it out sometime. -
Thanks guys for the replies
They are .mov files that uses PNG as the video codec (2 Digital juice background animated movies)
I tried in Adobe Premiere under Interprete Footage to just change the frame rate to 25fps, but didn't got a good result.
I will try your suggestions and see if it will better.
Thank you -
Zoki, you're better off dropping the PNG's into a PAL Project Setting and let Adobe conform the footage to the output project...
Make it a separate sequence, or output as a separate .AVI..
There's many other ways to do this, but try this first..
Convert BluRay to MKV with MKVmerge no FPS set
By whachano in forum Blu-ray RippingReplies: 0Last Post: 23rd Feb 2011, 16:16 -
Any way to convert 25 to 30 fps? ( 'cos YouTube is broken)
By MJ Peg in forum Video ConversionReplies: 16Last Post: 5th Aug 2010, 05:17 -
I need to convert 24p to 30p fps - please help
By Comfy in forum Video ConversionReplies: 3Last Post: 15th Apr 2010, 08:09 -
Convert HD 1280x720 25 / 30 FPS > MPEG2
By squadjot in forum Video ConversionReplies: 4Last Post: 8th Sep 2008, 11:20 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
