hi,
i have trobule with ripping dvds with handbrake and/or mac the ripper.
handbrake works fine with most of the region 3 dvds that i own,
but more than half of region 1 dvds i can't rip.
mac the ripper claims they have bad sectors, while handbrake won't recognize their video folders.
what would be the cause??![]()
thanks in advance.
Results 1 to 9 of 9
I suspect you're using the free MTR 2.6.6, which doesn't
play nice with the newer protection schemes. You need
the donationware MTR of the 3.0 persuasion. Go to
http://www.mactheripper.org/
and join the forum to see how to get the latest beta, which
does a real nice job on the more recalcitrant DVDs.Al Bloom -
is it possible that it has to do with the region set in my dvd drive as default?
i set it up for region 3, which i often view... i can rip region 3 dvds fine...
do i need to hack my dvd player installed in my mac?
Originally Posted by albloom -
Depending on what drive you have, you may be able to
flash its firmware to region-free status. Check rcp1.org.
Lots of goodies there.
Then you can use RegionX (macupdate.com) to reset the
number of region changes you've made.Al Bloom -
I have powerbook g4 (Matshita?). i looked it up, and it doesn't appear that i can hack it. maybe, i should buy an external drvie, then make that drive region free...everyone seems to recommend pioneer dvd 110d...Originally Posted by albloom
i'm new to this, and thanks for your help! -
The 110-D is a good one (I have it and it is flashed) but good luck finding one.
i found one at tigerdirect... is this the one i need?? and compatible with mac?Originally Posted by lawnman
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1696969&Sku...6&cpncode=11-1 -
I suggested that site and drive to some people over at ripdifferent and tigerdirect sent them 111-D instead so be careful.
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Mac - Handbrake: all x264 filters off? - MKV
By heinza in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2011, 20:26 -
Mac The Ripper Help
By fugly in forum MacReplies: 5Last Post: 17th Nov 2008, 08:35 -
ImgBurn/Handbrake for Mac?
By chronic777 in forum MacReplies: 4Last Post: 17th Oct 2007, 22:59 -
Help with Mac the ripper
By Phate in forum MacReplies: 1Last Post: 22nd Jul 2007, 13:12
