Ok, info is as follows, not a newbie, know how to use TMpgEnc software, can convert DiVX to vcd no problem. The query i have is that some files i have are encoded in MPEG-4, Microsoft's version of DiVX as I understand. When trying to open with tmpgenc it says unsupported file type. The AVI file plays fine under media player 7 with the mpeg4 codec from MS. Under the properties (right click avi file) preview though it will not display. If this is because i do not have that codec, is this why tmpgenc will not recognise it, and where can I get it, if that is the case, or will tmpgenc just not support mpeg-4? If so, is there software that will convert it.
Many thanks if somebody can help.
after days of head scratching and finally posting to forum, i have sussed an hour after posting! guess i would never have done it otherwise
I loaded up Krystal codec pack and mpeg-4 works a dream now under tmpgenc and also preview pane on properties tab! thats what u get for trusting microsoft to produce working software LOL!
sNoWy1998,
Maybe, I can help you!
Well, if you say you play your Mpeg-4 files on Media Player 7. So, you have the correspondent decoder in your system, right?
What you must do is to inform TMPEGenc about this. How?
Go to TMPEGenc "Option" => "Environmental setting" => "VFAPI Plug-in". You'll see the encoders that TMPEGenc recognises in your PC system. Next, set Mpeg-4 decoder to the highest priority and try "Preview" again.
I hope help you. If not, please come back us.
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
DivX to Mpeg -> DVD Conversion is Jerky
By jedijfo in forum Video ConversionReplies: 4Last Post: 15th Oct 2007, 08:32 -
mpeg-4 conversion help.
By ruk_design in forum Video ConversionReplies: 2Last Post: 28th May 2007, 03:18
