Can someone tell me how to stop VirtualDubMod from taking over my PC?
I'm using it to take a DivX movie, resizing it and saving it as a DivX movie again.
In a post sometime ago, someone told me that I could control it by changing it form being in Full Processing mode.
As I remember... you could set this up before... or even during conversion.
I can't seem to find out how to do this while resizing my DivX.
Thanks.
OM
sorry... i mean it hogs the cpu.
so... when i try to use other applications... i have to wait much much longer for them to laucnh and respond when i do things.
does that make sense? -
Open up Task Manager.
Right click on the process.
Choose Set Priority>Low. -
You have to turn on the status display, then you can choose how much CPU to give it, from normal, all the way down to low.
You can lower it's priority, but at the expense of slowing down it's operations.
Most any encoder uses close to 100% of the available CPU power. If it didn't, it would take longer to complete the encode.
Of course if you have a fast CPU, you could slow it down to maybe 75% and not lose too much speed. But any other computer tasks should be ones that don't demand to much from the CPU. I wouldn't recommend a game of Doom, for example.
Lowering VirtualDub's priority does not slow it down appreciably if you aren't using other CPU intensive tasks. I usually run it at Idle priority:
You can set the default priority via Options -> Preferences.
Burned Divx movies stopping before end...
By Jeffross1968 in forum DVD RippingReplies: 9Last Post: 18th Feb 2012, 12:08 -
Video Keeps Stopping On My Site
By Frustrated1 in forum MacReplies: 16Last Post: 5th Apr 2010, 01:59 -
How to burn DVD that plays all chapters without stopping?
By billdz in forum Authoring (DVD)Replies: 28Last Post: 2nd Nov 2009, 06:53 -
Play divx files without stopping
By occasional in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Feb 2009, 08:20 -
Capturing and stopping via command line
By diamond187 in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2007, 17:03
