I was wondering if there was a way to put visualizations (and if there is, what program is best?) on a cd that has mp3'z on it so when I play it on my home dvd player it won't burn a permanant image into my HDTV. The screen doesn't change at all and I was worried about it burning and image, not to mention it would be cool as heck to have 52"s of trippy visualizations
You'd need to do a Video Screen grab (CamStudio, Camtasia, etc) while the mp3 is running in WMP (or whatever the source app for the visualization). Then edit & convert that to a format that'll play on your settop (MPEG2 for DVD-Video; DivX/Xvid/MP4 for some others; possibly WMV...).
Those are generalities, but that's pretty much the only way to do it that I know of (barring shooting the screen with your videocamera!).
Scott -
There was a Toshiba DVD player can do that : SD2300. See : http://www1.epinions.com/elec-review-2D2-3D155EFF-3A229F11-prod6
?Virtual Light Machine? can be activated during CD-Audio playback and displays up to 100 unique patterns that pulse and change in sync with the music. If you ever used WinAmp MP3 player on your computer with visualization plug-ins, you know what I mean. -
thats precisely what I do - patched the Video to the TV using the 'tv-out' option, and the audio is routed through my home theatre system.
Its a pretty good option all around, I think.
I have also played around with the option of capturing the screen in winamp and wmp10 - the visualizations. It works pretty well, but (And this is my own humble opinion) the price of the software I paid, just to do that wasnt really worth it.scratch the surface off a cynic - you will find a disillusioned idealist.
Put mp3 audio file from hard disk to forrum post
By vitcon in forum ComputerReplies: 5Last Post: 18th Mar 2011, 11:11 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
trying to record "visualizations" in Windows Media Player
By yankeestonk in forum Video Streaming DownloadingReplies: 5Last Post: 12th Mar 2009, 18:11 -
Rendering Visualizations from Audio
By chintue in forum AudioReplies: 7Last Post: 8th Dec 2007, 17:20 -
DVD plays Windows Visualizations instead of Video
By Darkkman in forum Software PlayingReplies: 2Last Post: 7th Jul 2007, 03:30
