The VOB file is 550MB, yet I end up with a file 38MB when trying to author a DVD with TMPEnc DVD Author. The output file is really nothing more than the created menu and a small portion of the VOB. Suggestions?
Results 1 to 13 of 13
how did you make the vob? downloaded? ripped? try fix it with it for example Videoredo first (quickstream fix) or demultiplex it(split audio and video) with pvastrumento and import the video and audio files in tmpgenc.
Go to chapter edit, and slide thru the entire VOB file's video. That is to confirm the VOB file is intact and not broken.
Using the slide feature in the chapter edit section, only the last 20 seconds of a 15 minute VOB is shown. This is also apparent in the chapter edit thumbnails.Originally Posted by SingSing
After the first viewing, I can then move the slide back to the start point. The VOB then appears to play the full 15 minutes. However, the thumbernails still just show the last 20 seconds. -
It is a downloaded VOB, from a private members only torrent site.Originally Posted by Baldrick
No loss, no encoding, no conversion - just repackaging the video and audio back to a format more suitable as source material for creating a video DVD.
/Mats -
I used vob2mpg on this vob. And sadly ended up with the same results. TDA would only use the first 22 seconds of a 12 minute vob.Originally Posted by mats.hogberg
I tried Power Producer, it accepted the vob, but more than doubled its size. During playback the Power Producer created dvd pauses in spots, like dvds created on some Panny dvd recorders. I guess I may need to repair this dvd or maybe re-install TDA. -
I guess you'll have to find this video you so desire in a not damaged format.Originally Posted by pinetop
/Mats
File output issue from TMPEnc Author Works, VOBs -> single MPEG2
By aln688 in forum Video ConversionReplies: 4Last Post: 10th Apr 2010, 21:17 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 07:23 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 22:39 -
Need help on how to author a DVD w/clips into a small section of the screen
By mbextreme in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 05:22 -
Xvid Mencoder - output File too small (lower bitrate)
By grim1234 in forum ffmpegX general discussionReplies: 5Last Post: 25th Aug 2007, 19:48
