I just got a ps2, and I'd like to hook it up to my wireless b router to play some games online. I realize I could buy a $100 wireless bridge, but I'm curious if that usb port on the ps2 can handle netowrk traffic. I have a Linksys WUSB11 usb adapter that I use for my tvio series 2. It's an external box with an antenna and a male usb plug. Can I use that adapter with the ps2?
Thanks!
Gary
You can get the Linksys WGA11B at Amazon for $19.99.
http://www.amazon.com/Linksys-WGA11B-Wireless-B-Game-Adapter/dp/B0000AJVBW/sr=8-1/qid=...&s=electronics
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=...VisitorWrapperNothing can stop me now, 'cause I don't care anymore. -
Thanks for the reply! I stumbled upon that little guy a few minutes ago at amazon and went ahead and bought one. Can't beat that price, compared to the other "game" adapters going for > $60.
Thanks again!
Gary -
Not sure why, but this little guy that I bought on Tuesday for 19.99 is now 59.99. Was Amazon just having some kind of awesome sale?
Crazy. -
Also, as a followup, in case anyone finds this page while searching for PS2 game adapters...
If you're ready to pull your hair out because you're 90% of the way there (WGA11B talking to the router (responds to a ping) but the PS2 can't even test the connection successfully...try a different cable between the WGA and the PS2. Apparently, that crappy cable that came with the WGA was faulty, but a different cable worked fine. Wasted over an hour researching and trying different things..."it can't THAT simple...could it?"
Gary
wireless Networking (router trick)
By stiltman in forum ComputerReplies: 0Last Post: 25th Mar 2009, 23:18 -
Does Windows 2000 do wireless networking good?
By zzyzzx in forum ComputerReplies: 11Last Post: 21st Oct 2008, 12:21 -
Wireless lavalier mic options
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2008, 21:14 -
Networking for a moron -- wired and wireless.
By Xylob the Destroyer in forum ComputerReplies: 2Last Post: 23rd May 2008, 12:47 -
Wireless options for dialup?
By bobogs in forum ComputerReplies: 4Last Post: 10th Aug 2007, 23:49
