I just converted four avis that took around 4 hours each. I didn't check the audio to make sure it was ok. Unfortunately, the audio screwed up. I took one of the mpg files and de-multiplexed it to check the mp2 file. I got a 52mb mp2 file which had nothing but silence on it. Is there a quick way I can convert the old avi audio to mp2 audio so that I can multiplex the audio with the video without converting the avi to mpg again? I think tooLame is able to do this, but I have never used this tool before. Can anyone help? Thanks
<font size=-1>[ This Message was edited by: Lepy on 2002-01-11 21:31:57 ]</font>
Easiest way might be using toolame with TMPG.
Option > enviromental setting> external tool> Layer-2: toolame.exe.
Load the avi as video (and audio) source, select audio only and configure the audio output at the audio tab.
Make sure the audio source is uncompressed. If not, load the avi in VirtualDub and save wav.
<font size=-1>[ This Message was edited by: Truman on 2002-01-12 09:50:30 ]</font>
how to convert mp2 audio to lpcm?
By gareth41 in forum Authoring (Blu-ray)Replies: 9Last Post: 21st Oct 2011, 14:47 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 01:46 -
Merging mp2 video and audio - on a MAC
By Carder123 in forum Video ConversionReplies: 0Last Post: 26th Apr 2010, 07:24 -
MP2 audio with LAME?
By RogerTango in forum AudioReplies: 7Last Post: 3rd Nov 2009, 23:28 -
Extract audio from MP2 and more
By txl in forum AudioReplies: 7Last Post: 30th Jul 2009, 07:49
