Hi there,
So far, using ffmpegX on my Mac has been great. Only now I have this problem I cannot fix with a matroska file.
I am trying to convert a h264 mkv-file to xvid avi using the xvid-ffmpeg encoder. Encoding the video is no problem, but the audio track is impeding progress. The original has 5-channel dts audio.
It does not matter which output I select. Leaving the audio track "0" in the audio tab will always lead to this error in the progress log:
"Unsupported codec (id=86021) for input stream #0.1"
When I put the audio track to 1, it would give me this:
"Could not find input stream #0.2" Same goes for the rest of the tracks.
Does anyone know a way around this problem? Thanks,
nickelvd
(1) Not all encoders support Matroska. ffmpeg doesn't. I don't remember which one works as I experimented all the encoders with Matroska several month ago. I think it's mencoder.
(2) It will be easier if you use MKVToolnix.
Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
How to convert matroska MKV to AVI or OGM to AVI
By Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 00:56 -
AVI Motion JPEG to x264 in Matroska MKV container
By Michielvsb in forum Video ConversionReplies: 2Last Post: 20th Apr 2011, 03:12 -
How to convert MKV Matroska to Avi or Divx including audio tracks and sub
By s.elmagnifico in forum User guidesReplies: 0Last Post: 16th Aug 2008, 08:47 -
GUI to convert Matroska (*.mkv) To AVI
By qwerty9876543 in forum LinuxReplies: 4Last Post: 17th Mar 2008, 21:38 -
Problem playing .mkv (matroska)
By mk2006 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2007, 04:33
