hi, i have just few question bout ulead dvd woskshop 2, however b4 the questions here is my situation. I have completed transcoding 13 files using ulead dvd workshop 2, all the files b4 where AVI format so now they are stored in my HD in this folder DWS_TS. ok after that i have troubles with my OS so what i did i format every thing except the transcoded files...when i install the Ulead again and jst open the project coz i want to burn it again
note: i used the same settings b4....the bitrate,resoultion,etc....
do i still have to transcode everything again????
does Ulead have a way not to transcode everything as long as the finish product is in your HD????? (refering to DWS_TS folder where CvtMenu, CvtTitle XMakeDisc are in)
any tip would be appreciated...thanks again![]()
You should just be able to open that folder and burn, there is no further need to encode again. You may need to import those files into a new project for workshop to see them, but there will be no need for more encoding.
Google is your Friend
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 09:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 22:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 02:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55
