is it possible as i got a queen greatest hits iso with dts sound and i want to ripp the music from it for my car,when i extract it in iso buster it sounds like loading up one of those old commodore 64 games,anyone got any ideas as i heading of to melbourne to morrow from north queensland and love to be able to rip this iso any help is great thanks
Closed Thread
You need to convert the DTS to stereo audio. DTS audio is only playable through a digital (Coax or optical) connection to a DTS decoder. If it isn't decoded you get pink noise, which can blow speakers if it hits them loud enough.
You could try the Hypercube Transcoder to get it into a state where you can then convert it to PCM audio for CD.Read my blog here.
daemontools can mount the ISO so it appears to your system like another CD/DVD drive. You can then access the contents like any other DVD.
Read my blog here.
You could also use DVD Audio Extractor.
Which is stated as having a 30 day free trial. I don't know as i bought mine a long time ago because it's great & i use it a lot!!
One program one step.
It will rip and convert to wav (all six channels or stereo), mp3, ogg, direct stream or even rip an image & cue sheet straight from the disc.
Or you can use DVD Decrypter to rip just the VIDEO_TS folder contents (which is where the DTS files are) to your HDD & convert from there or if you use the ISO image just mount it as guns1inger stated and use DVD Audio Extractor to rip it right to wav or image and cue sheet then just burn it to a cdr.
You can also do it by chapter points or just the full disc as one long song.
Looking to get started Ripping. Been Doing .iso but what's better?
By Cyronaseez in forum Blu-ray RippingReplies: 8Last Post: 8th Apr 2012, 00:02 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
ripping DVD to ISO
By scarlac in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2009, 19:10 -
Ripping from vcr discs gives me strange ISO files
By sky captain in forum Newbie / General discussionsReplies: 1Last Post: 4th Jun 2009, 12:32 -
iso buster and ripping mpg's
By kshavo in forum Authoring (DVD)Replies: 4Last Post: 8th Feb 2009, 06:46
