I am having a problem with Nero and other programs hanging after finishing or when I am trying to close them. Windows 2000 says that the program cannot be closed because it is being debugged. I have researched and found that Dr Watson is the Windows 2000 debugger. However, I cannot find info on how to disable Dr Watson debugging, or how to stop the debugger so the app can close. I end up having to power down windows, which has already caused a problem with my new Segate 500GB drive.
Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
first hit on google
http://support.microsoft.com/?kbid=188296
How to disable Dr. Watson for Windows"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
you can also stop Dr. watson in the task manager if it is running
Originally Posted by BJ_M
Deleting it from the registry seems a bit extreme. But your second thought is good, however it is not a task I see running in Task Manager. I have very few Tasks listed in Task Manager. I have eliminated as many as possible to speed up windows.
I was wondering if you could turn it off as easily as microsoft says you can turn it back on. Perhaps deleting it from the registry is the only way. Deleting it from the registry seems like a last resort.
I want to stop the debugging of the program, so it can be closed. It seems like you should be able to go into the debugger, and stop the debugger debugging the current program.Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic -
you can easy make two batch file scripts on your desktop - one to turn off and one to turn on ... then just click either one ...
real simple to do"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
It doesn't necessarily follow that Dr Watson is the culprit debugger here.
A lot of programs that have time limitations, built-in license handling etc (such as Nero), use one of a number of off-the-shelf tools to "wrap" the software in a shell that controls whether the main program should be allowed to run or not. These wrappers also server to prevent hackers from reverse engineering the product. One of the things that the wrappers do is act like debuggers themselves.
I wouldn't be surprised if Nero is crashing and it's own protection wrapper is preventing it from being closed down.John Miller
"Protection error - Debugger Detected"
By DaveMidgley in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2011, 14:35 -
Turn of visualization
By musomn in forum Video Streaming DownloadingReplies: 5Last Post: 23rd Oct 2009, 12:32 -
dr watson error on thumbnails
By zootedlooter in forum Newbie / General discussionsReplies: 5Last Post: 14th Sep 2008, 06:24 -
HELP with some computer problem,won't turn on??
By demolitionman1985 in forum ComputerReplies: 6Last Post: 8th Sep 2008, 12:35 -
Laptop Problem: Does not always turn back on...
By Super Warrior in forum ComputerReplies: 10Last Post: 16th Feb 2008, 06:19
