Can NEC nd-3550a dvd writer read DVD-RAM (4.7)? When I put in the disc, my writer can't run it. Here's the info of my dvd writer.
Code:NEC 16X DVD±R DVD Burner Black IDE/ATAPI Model ND-3550A - OEM Cache: 2M CD-R: 48X CD-ROM Access Time: 140ms CD-RW: 32X DVD+R: 16X DVD+RW: 8X DVD-R: 16X DVD-ROM Access Time: 160ms DVD-RW: 6X Type: DVD Burner Model #: ND-3550A BK OEM Item #: N82E16827152058 In Stock
Did someone tell you they did ?
Because as far as i know they don't read dvd-ram disc's.
http://www.newegg.com/Product/ProductList.asp?DEPA=0&type=&Description=NEC+nd-3550a&Su...o.x=15&Go.y=33
Newegg list's the ND-4570A as reading & writing dvd-ram,
http://www.newegg.com/Product/ProductList.asp?DEPA=0&type=&Description=NEC+dvd-ram&Sub...o.x=21&Go.y=30
But i use 2 dedicated TOSHIBA SD-M1712's for reading ram as i only use dvd-ram for recording on my standalone dvd recorder. -
Maybe with one of the Liggy's and Dee's firmwares they could because supposedly you can crossflash among different drives. I have not tried it and wouln't risk it though.
Dvd-ram is a diff. format, you can't adapt something to read it with firmware.
It's like trying to read a dvd in a cd-rom drive, it's not happenin'.
Verbatim DVD+R #96526 100 pk purple label WARNING - reads CMC M01
By xctrekker in forum MediaReplies: 11Last Post: 15th Apr 2012, 18:17 -
DVD Rom reads DVD but won't play DVD
By cougaris in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Jul 2008, 22:58 -
Dvd Burner only reads older dvds, won't read newer ones all the sudden??
By kpaxfaq in forum DVD & Blu-ray WritersReplies: 6Last Post: 28th Feb 2008, 15:11 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
Really, really weird issue with NEC 3550A
By ioannisds in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st Jul 2007, 15:07
