i need help to convert real player audio files to mp3 ..which is the BEST software available to convert rm files to mp3i have already tried switch plus, but i lose sound quality using switch plus . .any other softwares?
plz help
Results 1 to 10 of 10
It probably depends on what format the audio is in. Some information about Real Audio: http://en.wikipedia.org/wiki/RealAudio
A few programs that may work: MPlayer, Streambox VCR Suite, ffmpeg. (Or maybe ffmpeggui, which would be easier to use.) -
Using any music editing / recording /converting software (try using SPAM ). To get your work done , First play the Real audio files and then record. Now save the recorded file as mp3 format.
You can also try dbPowerAmp, but you'll need to visit their Codec Central for the Real codec.
If cameras add ten pounds, why would people want to eat them? -
dbPowerAmp like the previous post (unless things have changed) is real time only. ffmpeg should work for most ra files since cook audio was added to libavcodec some time back. Otherwise there is mencoder. Transcoding lossy to lossy like that you are always going to lose sound quality.
I still use Total Recorder. Haven't tried it since I last exorcised anything 'Real' from my laptop. It intercepts the stream from nearly any player and can usually do it at much less than real time.
If it's intercepting in realtime, how can it do it in LESS than realtime?
Originally Posted by celtic_druid
Originally Posted by kschang
Perhaps "intercept" is confusing. How about "grap" or "download" or even "ftp." (technically no, but ya get the gist).
I did not know Total Recorder can do that, I'll have to look at it again.
How will an MP3 audio file will compare with a AAC audio file?
By ConverterCrazy in forum AudioReplies: 6Last Post: 31st May 2011, 02:01 -
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01 -
How to merge audio file(mp3) and a video file (flv)
By suresh3484 in forum Video Streaming DownloadingReplies: 0Last Post: 20th May 2008, 00:15 -
swf-audio file to mp3
By dexus in forum AudioReplies: 6Last Post: 30th Dec 2007, 19:42 -
Converting audio from a mpeg file to a mp3 file?
By hrace in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 16:15
