If you are so inclined to answer.....you ever start making money on this site?
Results 1 to 18 of 18
AnonymousGuest
That would be a very nice job.
An he would make lots and lots of money. -
Yep and it's my job...or I'm a "web programmer" with my own company. I code some other sites too but the main income is from videohelp.com banners / sponsors.
Question: I notice the over all VH has been pretty secure while many other PHPBB sites often get hacked. Is this your special doing?
I just install the latest important phpbb security fixes as fast as possible. But I missed one some months ago when a user took over my admin account.
The main site hasn't been hacked....yet...
Wow. Someone took over your admin account?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Yep, it was possible because I use the option "Log me on automatically" so the hacker only needed a cookie with my userid and autologin set to true. It has been fixed in newer versions of phpbb.
And it was only my phpbb forum admin account....not the server account, I don't use any autologin for it...
So where are the dubious posts
Just wondering since overall the site has seemed okay and to be honest phpBB security kinda scares me away from it
Current versiona of phpbb is about as secure as it gets, there are no known exploits and if there were they would get fixed. If you search the phpbb forum any post you'll find about getting hacked will be a older version. Just like any software you have to update it.Originally Posted by Faustus
Its only as secure as the current exploit release. Thats like saying people viri are all using old Version of XP. Generally its true but the OS has a record of major security wholes being located at a fairly regular basis. Same for phpBB, it has a shakey history.Originally Posted by thecoalman
Security holes are in every software package. Just like XP, phpbb is a big target. Get on the mailing list and you get informed of updates as soon as they are available. BTW phpbb 2.X just went through a major security audit, there was about 3 or 4 updates released over the last 6 months or so that addressed potential security threats.
Again I'd suggest going to the phpbb forum, you'll find very few people mentioneing their forum was hacked and where you do they are using an older version. -
I guess I just prefer to have a lower profile. Like using a Mac.
I don't want to mod up a forum and then have no clue how to apply the patch without undoing everything. -
The updates come in a variety of packages. Thje two basic ones are files if you have no mods, simply upload and overwrite. Or a mod script if you have a modded forum. This can be manually applied like you would apply any mod, find and replace, find and after add etc. You can also apply it with Easy Mod which will apply the patch automatically and should work 99% of the time without any hitches. It only becomes an issue where the mod script conflicts with a mod you have applied. In that case you simply stop the easy mod installation and manually apply the lines that have a conflict. Delete them from the mod script and reapply the rest of the mod with easy mod.
https://forum.videohelp.com/viewtopic.php?p=1490526Originally Posted by Craig Tucker
That was an odd moment. It is the very good test for you! It(he) will help you to learn(find out) more about that as far as you depend on the Internet?
Hey Baldrick, ever see this?
By lordsmurf in forum FeedbackReplies: 3Last Post: 12th Nov 2009, 08:02 -
Baldrick
By sheftic in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2009, 02:33 -
To Filmboss and Baldrick
By jbitakis in forum Authoring (DVD)Replies: 3Last Post: 14th Nov 2008, 10:33 -
Baldrick
By MosThaTeD in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 21:09 -
Baldrick's Online calendar?
By hech54 in forum Off topicReplies: 2Last Post: 30th Jul 2007, 13:50
