I domnloaded a 698mb avi, and then using aprogramme called SVCD2DVD converted it so I can burn it to DVD using sonic. Now I've converted the file Sonic tells me it is to big to fit onto a dvd disc. Do the files get larger when converted? Is there a way to compress the file so it will fit? and also is there a programme I can use to split the file and put it on 2 dvds?
Sorry if I sound stupid!
burn the video_ts folder with something else, https://www.videohelp.com/author#3;25
Answer to all three questions is YES.
How big is the Video_TS folder? Did you feed Sonic seperate video and sound files, and was the sound AC-3? Older versions of sonic would convert this to LPCM, which makes the audio file about 10 times larger. Workaround is to mux the files before giving to Sonic to author.
BTW, Sonic is a poor capture program, bad encoder, limited authoring, with barely passable burning features. It is, however, one of only two progs I have found which can cut a captured 24FPS progressive file with pulldown flags and AC-3 sound and maintain audio synch. So it's not ALL bad.
I would also suggest you do some reading here as there is an awful lot of information you really need to know. -
easy divx to dvd may help you, i have converted a 800mb avi file to dvd, it have itseft's burning engine. i get it at SPAM
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator redwudz
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2012, 00:39 -
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 02:53 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14 -
395MB folder to big to fit on 700MB CD in ImgBurn
By happydog500 in forum AudioReplies: 30Last Post: 30th Jul 2008, 13:58
