Hey folks,
I am frameserving TV episodes from Vdub through CEE SP2 (the newest from Cinema Craft). I finally (finally!!!) got the Vdub filter setting to where they do a good job. Problem is, I have to set the output bit rate pretty high and change the frame rate from PAL (25 FPS) to NTSC (29.97).
Now, the output video file looks great. But the audio is garbage. So I then demuxed the audio from the video and tried it again.
The output video (in NTSC format) has about 20 seconds of black, blank footage at the end. Remuxing the audio is now a problem because the the video and audio are way out of sync.
Probably a bitrate problem, but I have no idea how to fix it. Any ideas??????
Thanks!
Chris
Hi-
Probably a framerate problem. Why not keep the video the same framerate (25fps) and then run DGPulldown afterwards for 25->29.97. The audio won't have to be stretched doing it that way, although there's a chance you'll have to apply a delay when authoring.
Or alternatively, encode for 23.976fps (NOT 29.97fps), and run standard pulldown afterwards. The audio will have to be slowed if you do it that way. BeSweet has a 25000-23976 preset.
That doesn't make a whole lot of sense to me. You can set the bitrate to whatever you want.
Also, don't let CCE touch your audio. Demux it and handle it separately and add it back in when authoring. Feed CCE an audioless video. And frameserving using AviSynth is better than frameserving via VDub -
Hey,
Well, I don't know how to do anything with AVISynth. It's all Greek to me.
I set the bitrate high to get the best quality output. I don't guess I "have" to set it high, but as I want to convert these files to DVD for play on my standalone player, I wanted to shoot for the best quality.
I tried 23.976, and a large chunk of the bottom of the video was cut off. Missing altogther. So I just left that setting alone.
As for pulldown, I am not even remotely sure of how that works.
P.S.
I no longer feed audio into CCE. Like you suggested. I quit doing that days ago! -
Well, if what you feed CCE isn't DVD compliant, it's going to resize it for you, possibly in ways you might not like. If you just drop an AVI in it (very bad, by the way), you may not get a DVD with correct AR. Look, just open the AVI in FitCD and use the script it gives you to send to CCE. Here's FulciLives' guide:
https://forum.videohelp.com/viewtopic.php?p=1487285#1487285
DVD at high bit rate - Blocky & grainy on big screen
By nharikrishna in forum Authoring (DVD)Replies: 8Last Post: 27th Oct 2010, 03:46 -
A transcoder for some high video bit rate conversion.
By stevyL01 in forum Newbie / General discussionsReplies: 5Last Post: 25th Mar 2010, 14:09 -
Question about way too high bit rate video from digital camera
By jimdagys in forum Video ConversionReplies: 12Last Post: 16th Dec 2009, 16:14 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
High Voices and Audio Sync Problems
By canada8668 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2007, 18:51
