I have 4 VOB files that I want to burn to a playable dvd. I use IFOedit to create ifo files for custom dvds that I make, but I would like to make a menu. Is there a program that will create a menu without the process of creating a new dvd? I don't care how dull or generic the menu might look, I just need to be able to make one. Any suggestions?
If by make a menu you mean have a menu -- Try Titlewriter -- SimpleMenus -- Adds in about 10-15 seconds
or demux and use GUIforDVDAuthor, or use the 30 day demo of Tmpgenc DVD Author and the add Video function.
Read my blog here.
Originally Posted by natural_mystic
If you mean that you would like to make a dvd without having to encode the vobs, I would just simply import your vobs into dvdlab or any other athoring programs that accepts vobs ... create your menu(s) ... and then let the program create compliant dvd files for you.
Kay
DVD / Blu-Ray Menu Creation
By motown01 in forum Authoring (DVD)Replies: 3Last Post: 7th Oct 2009, 14:15 -
Is there CD/DVD menu creation softeware that works?
By Djard in forum ComputerReplies: 11Last Post: 14th Mar 2009, 17:46 -
Questions about DVD importing and menu creation
By Reading Bug in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2009, 15:24 -
DVD menu creation
By andrewgerm in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2008, 15:24 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 18:27
