  1. Help.... I am new to this Ulead Mediastudio product.
    I have lots of video captures in Quicktime format from a Kodak digital still camera. Ultimately I want to edit this into exisitng analogue and digital video footage I also have.
    As it is in Quicktime format I am trying to convert it via VE8 ... I select the option from the File menu..... I choose the format I want to output to......... the program goes ahead and converts and saves the output.
    When I then try and play the converted file all I get is the first frame from the clip and no audio. This happens to every quicktime clip I try and if I output it in AVI or MPG - makes no difference.
    What am I missing?? Help. Thanks.
    Apr 2004
    Miskatonic U
    While it says quicktime, it could well be mjpeg instead of mov format. Use avicodec or g-spot to confirm the actual codec being used. Once this is known, it is uaully easier to find a solution.
    Read my blog here.
  3. Thanks.
    Tried both.... CODEC not identified.
