Hi i have a film that i d/loaded but it is 2 disc's and they are bin & cue files. 1. can i join they as they are or do i have to convert them first if so what would be best to use.
Extract them with ISOBuster. From there it depends on their format what you want to do with them. If they are something like Xvid or similar, use VirtualDub and 'Append' the second onto the first.
If they are MPEG and you want to convert them to a DVD, don't join. Just encode separately if they are not DVD compliant and let your authoring program put them together. You avoid a lot of sync problems that way.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
