I am currently working on a compilation using TDA. Here's my problem.
I want to be able to play only the 1st track option for an intro & opening credits I have done, but on order to get the video to play just this file, I have to add a new track option & place just the intro file there, this works great, but now I am stuck with & unwanted menu page of this intro track, anyway for me to delete or remove this ... I am fine with it on the MAIN MENU page, I can just mark it as INTRODUCTION, my concern is getting off the Track Menu some how. Can some one help me with this please?
Thanks in advance.
Father knows best.
In the "display menu settings' on the generals tab you can choose "play only the first track' then in the bottom drop down list box - "display main menu". These settings will play your introduction track then display the main menu.
As far as hidding the introduction track from the menu you can edit a menu theme then shrink down the thumbnail, delete the track name, then drad them off the screen. TheyI will still be active but not visible.
I dont' think you can delete a track menu for that track but you can remove the listing by unchecking it in the chapter display tab in display menu settings.
Hope this helps.
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 10:00 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 13:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
