I have all my music on an external hd and am going to put my movies on them. I'm using a d-link medialounge to play them on my tv through my router without my computer being on. This device supports wmv9, mpeg1, mpeg2, mpeg4, xvid and avi (mpeg-4 layer only) which of these formates would be the best for quality and ease of encoding. I am just keeping the main movie with dolby or dts. I'm playing them on a 50 inch. I first thought I would use avi or xvid but the movies don't come out the best on conversion at least the ones I have done so far (autogk). I think if I can follow this person correctly (from another post, i've been reading a ton about this) I can just switch the vob's into one long movies with some type of converter (being that they are already mpeg2)? Is this correct or what would be my best format and what program should I use for it. Or does someone have a diferent suggestion?
Thanks for any help you could give
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
