    Jan 2006
    Hi!
    I hope someone can tell me this...
    I want to capture digital tv, how do
    I connect the digibox to my PC?
    Also, what card do I need? DVB-T or DVB-C?
    Thank you
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Well you either have a usb adapter or a pci card. Those are your two connection options (well and firewire for some devices).
    As for t or c options I am afraid I can't help you there. We use atsc here in the US for digital broadcasts.
    Jan 2006
    I'm gonna use a PCI-card, so I just connect a antenna-cable
    from the digibox to the PCI-card?
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Yes you should be able to. Most also have a rca video jack input or at least a svideo input so you can record from a vcr or video camera or whatever.
    Jan 2006
    alright, I have to check it out =)
    thank you for helping
