Hi,
I get this error when I try to use my fusion hdtv for over-the-air hdtv with a regular airel:
ep 18 decoder rendering failed. code-00 error none
After searching for a little while at the divco website and on yahoo I couldn't find a direct comparison. I also have an audio decoder error. However I show a 100% signal strength I just don't have any audio or video.
Now it was working just fine in the spring time. The only difference is I had a ati radeon 9250 that died on me so I replaced it with a nvidia fx 5500 pci card.
Has anyone else experienced a similar problem with fusion cards and a nvidia graphic card?
I looked at the most recent software download at divco.com but it says it includes 64bit drivers. I don't have a 64bit processor or OS. Should I still download the latest release? Will it default to 32bit drivers?
EDIT - The anlaog mode works perfectly on the card. In fact I only recently tried hdtv mode since I had cable installed in the same room as my desktop.
