  1. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Ok,
    so I've used IsoBuster to recover 3 damaged DVDs, I've managed to recover 2 (full recover) and 1 stopped at 80 % (i gess).
    So now what I'm I sopposed to do with the VOBS, I want to pass them to another DVD, but I don't know how to do that, do I need any special program. And I only have the Vobs, some of the othe files are damaged.
    Thanks.
    Apr 2004
    Miskatonic U
    You can demux the vobs to mpeg - Vob2mpeg, rejig etc can do this - or just try loading them into TDA to re-author.
    Read my blog here.
  3. Member PTsniper's Avatar
    Aug 2006
    Portugal
    And any of this program allows me to record directly to a new DVD.
    Preferably without have to convert them.
    Apr 2004
    Miskatonic U
    You can't use them as is because vobs on their own are meaningless. You need to reauthor them to make a DVD. If you use good tools (i.e. something not called WinAVI or NeroVision or DVD Santa) then they won't be re-encoded. They may be demuxed and re-muxed, but this does not affect quality.
    Read my blog here.
  5. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Alright.
    Thanks.
    So I use what you've said here right?
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I would use TDA so you can add new menus etc.
    Read my blog here.
  7. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Thaks, i'll try that.
  8. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Yupiiii!!!!!!
    It's victory, I can now see my damaged DVD again (in a new DVD of course :P) , and it was so damn simple.
    Thanks a lot man.
