This model is not made by Goodmans but another company have the right to use the Goodmans name. I believe this model is made by the same company that make Ferguson DVD's. WHY? I have managed to remove the Region Hack for this player with the same Hack for Ferguson.
But I can't get the VCD Hack to work. My model does not have the open/close button on the remote control.
$20 is promised to anyone who can solve this VCD Hack.
VCD is supported through firmware, not hacks. If your firmware doesn't support it (I know that in the past many portables simply did not support the format), you will have to replace the firmware with one that does support it, if such a firmware replacement even exists. I have a feeling you'll be keeping your money.
Could not find firmware update but model uses new IC (SPHE8202S). Any ideas welcome
Hack for the Toshiba portable DVD player SDP94S
By Charlot in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Mar 2011, 16:34 -
HELP, do you know how to hack a Sony DVP-FX950 portable DVD player?
By luisfe in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th Jul 2010, 01:36 -
Region free hack for Philips PD9000D/37 portable DVD player
By anu in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jun 2010, 04:31 -
Need Hack for RCA DRC6368 Portable dvd player
By jsmitty7 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 13th Aug 2009, 10:14 -
Hack Insignia NS-MVDS7 portable DVD player
By vorls in forum DVD & Blu-ray PlayersReplies: 9Last Post: 12th Nov 2008, 20:07
