I am trying to make a SVCD or VCD of Titanic thru this process
Clad DVD - dvd2avi - tmpgenc
problem is when i get to tmpgenc (SOMETIME only with TITANIC DVD) says problem with wav file when i select location but when it does work and the process is finish i tested mpg file NO AUDIO? i tried different way like doing the whole movie or haf or pars at time but still no audio on titanic MPG
HELP PLEASE
have you tried playing the .wav file directly first?
best bet is windows media player will give u some kind of buffer error. this also means tmpgenc won't be able to add the audio to your rip.
wut i did was to split the titanic vob files into 2 sets. then i treated the 2 sets as 2 different movies and ripped/encoded them. titanic and some other long movies create .wav files that are too big for media player and tmpgenc to handle, so u gotta split the vobs to create smaller size .wav files.
