I have been encoding AVI's to MPEG using Adobe Premere 6.5,now I need to do the reverse!
What's the best solution to reverse the process?
Quality counts!
Just to get an avi file that can be imported into the Adobe timeline would do just fine.
Thanks,
Bruce
Quality will be based on your codec and bitrate, not so much the program you use.
VirtualDubMod can load video files and handle the conversion to AVI.
Xvid is free but premiere hates it
Huffy is lossless and also free + premiere likes it
DivX isn't free for full features but it can compress to progressive video for free and premiere can handle it well -
I would go with Huffyuv, Lagarith, or even DV avi. Xvid and Divx are a) lossy - heavily lossy - even under good conditions,\, b)not deisgned to be edited - they are as bad, if not worse than mpeg2 for editing, and c)not handled well by early version of Premiere (including 6.5)
Isn't this basically a double post of this one ?
https://forum.videohelp.com/viewtopic.php?t=309349Read my blog here.
Easiest way to "black out" a small section of video in an AVI file?
By johnny905 in forum EditingReplies: 7Last Post: 24th Mar 2010, 07:14 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
easiest bluray to mkv conversion?
By jdfwarrior in forum Blu-ray RippingReplies: 5Last Post: 6th Jan 2009, 10:18 -
Painless AVCHD editing idea on low peformance PC
By DVDRW in forum EditingReplies: 4Last Post: 14th Aug 2008, 12:21 -
Easiest way to mix different audio into .avi video file?
By BertRito in forum AudioReplies: 4Last Post: 21st May 2008, 23:57
