I have been using ATI Radeon Card for Tv- out and watching movies on Tv using S-video cable. But audio comes out from the speakers connected to PC. Is there any way so that audio can also be played from my TV ?
You can use the same output from your computer as your speakers use. But you would need a switchbox to do it right if you don't want to unplug cables each time you switch from computer speakers to the TV.
You 'might' be able to split the audio into two with a 'Y' splitter and feed both, but it rarely works that well. -
You need to take a connection from the headphone or speaker out from your sound card, and feed it into the audio in on your TV. For this you probably need a 3.5mm stereo jack to twin RCA lead.
What Redwudz was pointing out to you is that if you do this, you will have to disconnect your speakers from your PC (if you have any) which might be inconvenient. In order to prevent this, you could purchase a switching box that would allow you to have both your speakers, and your TV plugged in at the same time, and you could switch between them as necessary.Read my blog here.
For convinent, you may want to use a Y-cables that spilt the audio to both.
Mute or shut off the PC speaker, when you want to play the movie on TV.
