A post I made in another thread made me think my cheatsheet might be useful to others. This is what I used to save preset configs into my own WinTV2000 setup ... and I've emailed it to friends who use WinTV2000:
WinTV 2000 Preset Configs Cheatsheet
If you want to set up preset capture configurations in WinTV 2000, print out
this page. It's a lot easier doing it from a printout than by switching
windows on your desktop. The good news is that you only have to save these
presets once. The bad news is that WinTV 2000 saves all presets in the
registry. If you are a klutz - accidentally saving an erroneous config - you'll
have to find it in the registry and delete it.
This cheatsheet takes into consideration that you're capturing a 720x480 MPEG2
program with 224k audio bitrate - a program you want to fit on a single-layer
DVD. In my opinion, capturing video at a pre-configured video bitrate produces
superior results to using a "default" setting and shrinking afterwards.
The settings below start at 1:02 (62 minute) programs and go up to 2:24 (2 hour,
24 minute) programs. The reason is because at 1:02, you're already using the
DVD max bitrate - and at 2:24, you're using the LAST video bitrate above 4000.
Below 4000, I've found that video quality gets a bit dicey. So, if you capture
longer programs, good luck - you're on your own.
TIP 1: If you're capturing from a videotape, know what the running time is first.
If it's a pro videotape, the running time should be printed on the tape box or on
the tape itself. If it's not a pro videotape (or you can't find the running time), watch it first and time it. If the running time is 134 minutes, choose the 2:15 - 135 mins preset to guarantee you won't have to shrink the result files.
TIP 2: If you're capturing a television program, you can only estimate. On the
average (network average) there are roughly about 2 minutes of programming for every 1 minute of commercial time. In short, if the TV program time is 150 minutes, you'd end up with about 101 minutes to burn after commercials are cut. But, this varies. So if you plan to edit out the commercials prior to burning, take this factor into
consideration.
Below are the program times followed by the video bitrate setting (per Videohelp
bitrate calculator):
1:02 - 62 mins - 9570
1:03 - 63 mins - 9452
1:04 - 64 mins - 9301
1:05 - 65 mins - 9154
1:06 - 66 mins - 9012
1:07 - 67 mins - 8874
1:08 - 68 mins - 8740
1:09 - 69 mins - 8610
1:10 - 70 mins - 8464
1:11 - 71 mins - 8361
1:12 - 72 mins - 8242
1:13 - 73 mins - 8126
1:14 - 74 mins - 8013
1:15 - 75 mins - 7903
1:16 - 76 mins - 7796
1:17 - 77 mins - 7692
1:18 - 78 mins - 7590
1:19 - 79 mins - 7491
1:20 - 80 mins - 7395
1:21 - 81 mins - 7301
1:22 - 82 mins - 7209
1:23 - 83 mins - 7119
1:24 - 84 mins - 7032
1:25 - 85 mins - 6946
1:26 - 86 mins - 6863
1:27 - 87 mins - 6781
1:28 - 88 mins - 6702
1:29 - 89 mins - 6624
1:30 - 90 mins - 6548
1:31 - 91 mins - 6473
1:32 - 92 mins - 6400
1:33 - 93 mins - 6329
1:34 - 94 mins - 6259
1:35 - 95 mins - 6191
1:36 - 96 mins - 6124
1:37 - 97 mins - 6058
1:38 - 98 mins - 5994
1:39 - 99 mins - 5931
1:40 - 100 mins - 5870
1:41 - 101 mins - 5809
1:42 - 102 mins - 5750
1:43 - 103 mins - 5692
1:44 - 104 mins - 5635
1:45 - 105 mins - 5579
1:46 - 106 mins - 5525
1:47 - 107 mins - 5471
1:48 - 108 mins - 5418
1:49 - 109 mins - 5366
1:50 - 110 mins - 5315
1:51 - 111 mins - 5265
1:52 - 112 mins - 5216
1:53 - 113 mins - 5168
1:54 - 114 mins - 5121
1:55 - 115 mins - 5074
1:56 - 116 mins - 5028
1:57 - 117 mins - 4984
1:58 - 118 mins - 4939
1:59 - 119 mins - 4896
2:00 - 120 mins - 4853
2:01 - 121 mins - 4811
2:02 - 122 mins - 4770
2:03 - 123 mins - 4729
2:04 - 124 mins - 4689
2:05 - 125 mins - 4650
2:06 - 126 mins - 4611
2:07 - 127 mins - 4573
2:08 - 128 mins - 4536
2:09 - 129 mins - 4499
2:10 - 130 mins - 4462
2:11 - 131 mins - 4426
2:12 - 132 mins - 4391
2:13 - 133 mins - 4356
2:14 - 134 mins - 4322
2:15 - 135 mins - 4288
2:16 - 136 mins - 4255
2:17 - 137 mins - 4222
2:18 - 138 mins - 4190
2:19 - 139 mins - 4158
2:20 - 140 mins - 4127
2:21 - 141 mins - 4096
2:22 - 142 mins - 4066
2:23 - 143 mins - 4036
2:24 - 144 mins - 4006
Good luck and happy capturing,
J. Alec West
Results 1 to 1 of 1
presets for Staxrip
By greendesert in forum Video ConversionReplies: 0Last Post: 7th Jul 2009, 10:06 -
Right Presets ? And how to encode ?
By macmithos in forum MacReplies: 1Last Post: 27th Aug 2008, 14:30 -
DVDauthorGUI chapter breaks cheatsheet
By AlecWest in forum Authoring (DVD)Replies: 8Last Post: 12th Jul 2007, 01:20 -
WinTV2000 video bitrate cheatsheet
By AlecWest in forum Capturing and VCRReplies: 0Last Post: 9th Jul 2007, 17:50 -
PVR150 - WinTV2000 tips
By AlecWest in forum Capturing and VCRReplies: 0Last Post: 9th Jul 2007, 17:17
