A little help please. Loaded Virtualdub, run setup, attempted to run th Capture part of the program, error message came back and indicated the Virtualdub could not find the Device (TV Card). Other Capture prograsm I use find the device an dI can capture why not Virtualdub? Thanks in advance
Bud
What type of system do you have?
I am running windows 98se and had to use the DirectX 8.0 patch. -
I use a WIN2000 Pro on a 1.7 GHz system with ATI Randeon Card. I have loaded Direct X 8 for WIn2K.
Problems re-using VirtualDub
By djdust in forum Newbie / General discussionsReplies: 17Last Post: 27th Apr 2011, 08:57 -
.mkv problems in Virtualdub
By alc112 in forum Video ConversionReplies: 14Last Post: 10th Feb 2010, 23:47 -
virtualdub dv type 2 problems
By sander815 in forum Video ConversionReplies: 26Last Post: 21st Nov 2009, 19:58 -
Problems with Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 09:23 -
A couple of VirtualDub problems.
By Rein Engel in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2007, 03:07
