We purchased a licence for this software not too long ago, and yesterday and today its been nothing but trouble in that it keeps crashing and the only way to reboot the pc is to push the reset button. It crashes at various points and has gone as far as 92%. We tried it out with smaller avi clips and they converted no problem onto dvd. Any ideas why it keeps crashing? The hard drive has been degragmented and space freed up. Has anyone else encountered this problem?![]()
Results 1 to 10 of 10
Well there are 4 Avi files and sometimes it only got as far as 4 % done, then sometimes it got as far as up to 90%. Perhaps it does not like converting files which are approx 1 hour long, of which I wanted to convert 2, the other are approx 20 mins. Out of interest, is it just vob files that are burned or all the BUP and IFO files as well?
It does everything. I have used it for quite some time without any problems like this, on videos from 10 minutes to 2 hours long.
What version are you running (it gets updated frequently) ?
Have you tried reinstalling it ?
If it has just started crashing, what else have you changed - codec packs ? updated a codec ?Read my blog here.
We purchased the licence in August and only the other day were aware that a newer version waw available. We now have Version 2.1. No codecs changed as far as I'm aware. Perhaps I'll try uninstalling and re-intalling it again.
I'm pretty sure that the particular avi is a cause.
I do not use convertx but the earlier version of similar VSO program.
I saw what you are describing, on my computer. I was curious about that and even notify VSO about it. That was some time ago when I had only 512 Mb of memory installed (I see that you have the same amount of memory). What happened was that the program encoding used all RAM and started to use abnormal amount of virtual memory, followed by 100 % of CPU use. After a while, when all resources were used, the computer would crashed.
But that was only with 2 particular avi's. Otherwise the program have worked OK with other avi files.
So, I suggest to try it on other avi files - it doesn't matter how long they are. -
Is there a way to save a project and go back to it later on? And if so, will it resume where it left off?
No. You have to load the avi and start again.
I would be contacting VSO support. You have paid for their assistance, so you should make use of it. I have not experienced and crashes or untoward behaviour from this programme in the past. I am running the latest version (2.1.0.148) without incident. I suepct you have a codec issue, but I couldn't pin it down further based on the details provided.Read my blog here.
Could also be a temp problem. Maybe your CPU heat sink is starting to get clogged up with dust? This kind of encoding takes lots of CPU.
/Mats
convertx audio
By denis1213 in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2010, 22:08 -
PowerISO and ConvertX
By Aristocles in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2009, 22:45 -
Serious ConvertX Problem
By Kupo in forum Video ConversionReplies: 9Last Post: 12th Jul 2008, 10:22 -
convertx to dvd
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 13:54 -
Trouble with AVI in ConvertX
By Squid_uk in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2008, 11:07
