Whenever I use vob2mpg to change a set of vob files, it uses the wrong audio. Is there any way I can select which audio to use?
Which build are you using?
ok. There is a build which allows you to select the audio... When i get the chance I will update.
VOB2MPG Pro: wrong default audio for separate titles
By aurgathor in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st May 2012, 10:09 -
Getting wrong audio stream with VOB2MPG Pro 3.2.2000
By mwebb in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 20th Aug 2011, 13:45 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Vob2mpg PCM audio
By schematic2 in forum DVD RippingReplies: 3Last Post: 24th Feb 2009, 11:33 -
VOB2MPG No Audio
By vernonator in forum DVD RippingReplies: 12Last Post: 3rd Feb 2008, 16:15
