Hi again guys.
After capturing a few clips with different programs, I noticed that all of them are have a bitrate of 1536kbps.
I am using Canopus ADVC110 for the capturing process.
Isn't that a low bitrate?
The audio in a DV is 1536. The video should be 25Mbits.
How do you check the bitrate? how big are the files and what's the runtime? -
If you are using a ADVC and inputing to the computer via FireWire, you're not capturing. You are just transferring the data from the ADVC, same as from a DV camcorder. The bitrate is set by the DV format and not adjustable.
1536Kbps is the audio bitrate. The video bitrate is fixed at about 25 megabits per second (Mbps). The total data bitrate, including error protection and audio streams is about 36 Mbps
And it doesn't really matter which program you use for the transfer. They all do the same thing.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Possible to convert a 5.1CH 4608kbps PCM audio track to a 1536kbps 5.1 DTS?
By fluxcapacitormb in forum AudioReplies: 4Last Post: 20th May 2010, 15:46 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54
