Hi guys, i've been fiddling the last few days with converting a DTS track from a NTSC movie (29,970) to mux with my PAL movie (25,000).
I'm doing this because the PAL videosource is much better quality, while the DTS track of the NTSC version is much better than the PAL audiotrack. In addition i need it to be pal (would be easy to just convert video to NTSC) because my TV doesnt display NTSC correctly
The total lenght difference over approx 2 hours is about 5 minutes. (ntsc version 5 mins longer)
Here's what ive done so far:
DTS >TransGUI > 6mono wavs
Soundforge [Time Stretch] > cut every wav down to the lenght of the pal movie.
SurCode > DTS file
Rejig > Mux to dvd
The thing is , its still not 100% in sync![]()
In the beginning of the movie the audio comes to early, on the end the audio is about 4-5 seconds late. Seems like i did not "shrink" the audio enough.
My question is, is there some sort of "universal" way to calculate the needed amount of "shrinkage" ? Be it in percentage, frames, time, doesnt matter, soundforge has enough options for this.
Thanks for reading this and maybe helping me out![]()
Hi-
You could use the 23976->25000 NTSC to PAL preset in Besweet on the WAV files. Yes, there's a universal percentage, and doing what you did wasn't correct.
25000/23976=1.042709...=104.2709%
You still might have to adjust the delay when authoring, but assuming the actual number of frames of the 2 versions of the movie is identical, you should be able to synch them up.
Also, if you have the right decoders installed, you should be able to decode the DTS to 6 mono WAV files in BeSweet, and do the stretch at the same time. -
hi, thanks for helping, the thing is, the original NTSC is true ntsc: 29,970 FPS
I've tried to go from DTS to WAV in Besweet (with the azidts plugin etc) with the 29,970 > 25,000 preset. Unfortunately Besweet screws this up, it changes the "pitch" too, which makes everything sound very slow.
EDIT
If that's true.. it would be 25000/29970 = ~0.83, meaning that i would have to cut it down to 83 %. That would pretty much destroy the soundtrack i'm affraid
But then again, the lenght difference is only about 5 mins over 2 hours, so 83% wouldnt be right anyway..
/confused
Just do what I said and you should be OK. You said there's a 5 minute difference in the lengths. So, even if the frame counts don't match up (although nothing you've said yet convinces me of that), they did speed it up by the 104+%. I said nothing about 29970->25000.
Everything else you've tried so far was wrong. What have you got to lose? -
lol
i'm not ignoring you mate, really apreciate the help, but every tool i tested says the framerate is 29,970. But you're probably right, im going to try it out.
So i reckon that conversion you suggested would effectively shrink the file from 104% to 100%? -
Well, I can't be positive unless I have both the NTSC and PAL versions of the DVD to examine, and giving advice from 12,000 miles (20,000 KM) away can be risky, but based on a lot of past experience, if you do it the way I suggested in my first post, yes.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Converting an NTSC DVD to PAL w/ DTS
By thisismyname07 in forum Authoring (DVD)Replies: 28Last Post: 26th May 2007, 23:57
