Results 1 to 9 of 9
    May 2006
    Macedonia, the Former Yugoslav Republicof
    Hi I have a problem with the resolution in Auto Gordian Knot I can’t get the resolution to be the same with the resolution of the source file. Even if I try to use a close enough resolution it still gives me a different resolution. I can’t find the resolution I need in the advance settings. The problem is that it gives me larger resolution that affects me picture the source file has 480x360 and that file I get is 608x352 thanks.
    Jan 2006
    Australia
    Well 480x360 is 4:3 however not in a multipule of x16, 608x352 on the other hand is 1.73:1 (nearly 16:9). It may help to output a 4:3 aspect
    May 2006
    I also can’t make the hidden options in Auto GK to work. Is there a way to fix that problem
    Jan 2006
    Australia
    Ctl+F9 if that doesnt work reload it, if that doesn't work it maybe a damaged source file
  5. Hi-
    And the source is another AVI? Do you have a GSpot pic of it you can upload, by chance?
    May 2006
    I‘ve tried with several different video’s and the parameters I put in the hidden options don’t work. The problem with the resolution appears and with a Mpeg 2 file I tried to convert to xvid its resolution is 640 x 480 and the resolution I get is 640 x 496. Here’s a screen shot of the G spot of the first file I tried to convert its resolution is 480 x 360 and I got 480 x 368.
  7. Hi-
    That makes more sense now. Why did you say 608x352 in the first post? It sounded like AutoGK turned a fullscreen AVI into a widescreen AVI, which it didn't. You fooled both me and drewzor.
    The answer, which drewzor also gave in his first post, is that AutoGK (correctly) encodes only for Mod16 resolutions (both widths and heights divisible by 16). That 360 height is only Mod8. AutoGK will make it either 368 or 352. It probably did some little cropping to maintain the AR.
    If you want to get it back at 480x360, you'll have to use a different program, or do it manually.
    As for the one it gave you 640x496, I don't have the log to go over. Maybe there was some black for it to crop. But I'd have to see a log to understand why it changed the resolution.
    And if you don't mind me being nosy, why are you reencoding and lowering the video quality?
    May 2006
    Thanks for all the help. I was reencoding the file because I wanted to merge it with the second part of the video but Ulead VideoStudio 8 was giving me problems with the codec’s of the video, It wouldn’t give me sound and there where squares those appear in the picture. Auto GK fix that problem for me. By the way the first post was correct after I merge the files witch had 480 x 368 resolution the conversion in Auto GK gave me 608 x 352 .
  9. Hi-
    So, was it a widescreen video to begin with, and AutoGK cropped away the black bars maybe? If you don't want it to crop anything, you can set it for no cropping in the Hidden Options.
    Usually the joining of 2 videos is done in VDub(Mod). There could still be a reason they wouldn't join (differing audio bitrates, usually), but if the video is 2 parts of a whole, it should join easily, although you might have to remove the audio first.
