What exactly is this? I am new to this and I am unaware of how to convert this file.
Results 1 to 11 of 11
rmvb is just rm. They changed the extension to make a distinction when Real Video 9 came out since previous codecs were CBR for streaming purposes. As for audio, real can use aac, cook, AC3 or atrac audio.
Convert to what? -
I am trying to convert it with convertxtodvd and it does not convert. I did it with another real player file and it worked, but it was labeled mpg, not real audio or anything.
If you have real player installed on your system then most video files will be called "Real Player File", regardless of what they really are. Only those with rm/rmvb extensions are actually Real Video encoded, and convertxtodvd cannot encode these yet.
Read my blog here.
convertxtodvd as I understand it is using libavcodec/format for input. So if ffmpeg can't decode it, then it can't convert it and ffmpeg only has limited real media support. Cook audio was reverse engineered, AC3 is of course supported as is aac and some of the old video codecs. RV9/RV9EHQ aren't supported. So basically no video. You need to use Real's decoder, either via dshow using Gabest's splitter or via mencoder.
Encode, as in convert videos to Real format, or convert the Real videos to a different format?Originally Posted by EesaIf cameras add ten pounds, why would people want to eat them?
I would like to encose these into another format.Originally Posted by redwudz
I am trying to encode it and I get a message saying 'scan idex out of". Does anyone know what this is?
[1.1.7/Win] Saving RealAudio streaming to file?
By yetanotherlogin in forum Video Streaming DownloadingReplies: 0Last Post: 4th Mar 2011, 06:51 -
What tool is idea to convert the RealVideo VBR into the DVD?
By coody in forum DVD RippingReplies: 1Last Post: 23rd Aug 2008, 10:16 -
RealVideo Source to MPEG2, problems.
By mattstan in forum Video ConversionReplies: 5Last Post: 4th Aug 2008, 05:06 -
converting RealVideo 10 to avi
By user543 in forum ffmpegX general discussionReplies: 2Last Post: 30th Oct 2007, 02:06 -
RealAudio - audio/x-pn-realaudio-recording ? HELP!
By radiowhiz in forum AudioReplies: 2Last Post: 18th Jun 2007, 01:13
