Results 1 to 9 of 9
    Feb 2005
    Hi guys, I'm looking for some images that would/might make good dvd menu images, they need to have some depth and be big in size to allow for some animation.... Any ideas?
  2. Google image search
    Feb 2005
    Quality is no good, I cant seem to find the right type of image, I rather pay for it and get good quality...I just need to find good images that would be good to use as a menu and have animation when they selected an option
  4. Give some kind of description of what you had in mind.
    Feb 2005
    Something that has depth where when you click on one of the titles it will be able to animate and change up a bit....Something clean and sleek....
  6. You mean Transtions?
    Feb 2005
    yea, you know just a bit of animation that will happen when the user selects Additional Content...
  8. You would need to design them yourself in a graphics program. You can't buy transition
    Jul 2006
    If yer looking for animated buttons, yer looking at ALOT of work. If u just want 3D buttons, tons. The background (wallpaper) if any should be non-descript and slightly fussy as to accentuate the buttons. Transitions are small videos that sit BETWEEN menus.
