I have used Graphedit and now I can't watch any video files on my computer.
This is Wat I have tr-yd to do ... but something went wrong. This Is The Link http://www.vladd44.com/video/vodei.php Pls Help
U don't have fate in fate ... but ...
Fate has fate in u -
Unfortunately, GraphEdit is not supposed to be available for download in the way that it is.
GraphEdit is part of one Microsoft's Software Development Kits and Microsoft state that it must not be distributed by itself. Apart from being spiteful, there may be very good reasons for this - and maybe the problem you have run into is one of them.
To help repair your system could be a painfully long process since playing videos relies on so many different components that all have to be correctly "registered". If using GraphEdit has changed any of the registered components, you will have to determine which ones.
To start with, we need to look inside your computer's registry. If you are familiar with regedit, you need to export the following registry key:
HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance
Post back if you need help with how to do this. If you are able to export the .reg file, please post that.
Armed with the information, we can begin to determine what is and isn't still registered correctly.
By the way, can you not play ANY video files or is it just a particular kind (format)?John Miller -
yes I need help .... if u can tell me how ( step by step ).It's seams I can't view AVI. file's
Ty for the help.U don't have fate in fate ... but ...
Fate has fate in u
MPCHC Video Audio & Video playback Problems
By skorpinok in forum Software PlayingReplies: 11Last Post: 1st Jun 2011, 10:26 -
New to video, several problems
By Tonyeng in forum Newbie / General discussionsReplies: 15Last Post: 1st May 2011, 21:02 -
Video playback problems after installing video editing suite - Please help!
By abeelandig in forum Software PlayingReplies: 2Last Post: 5th Aug 2010, 21:54 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Horizontal offset problems with video fields in video to DVD transfers
By aussiebloke in forum RestorationReplies: 3Last Post: 15th Feb 2010, 05:33
