    Jul 2006
    Good Day,
    I know that there is an enourmous amount of post addressing some of my questions. However,
    due to the excessive amount of discussions on each post; the answers become difficult to
    follow or understand. At times, confusion is added to a simple question.
    I am very new to video editing. I would appreciate easy to follow suggestions and tools
    I can use to accomplish what I want to do. You can recommend shareware, freeware and
    commercial products, including DVD Lab Pro and Adobe Premiere. Please keep it simple so
    that I and others can follow. You might be an expert on video production, but I am not.
    My goal is to rip the video/audio to my PC's hard disk. Edit the video; author the edited
    video and burn a DVD.
    I want to edit a DVD-R recorded and finalized on my Panasonic home recorder. I want to
    basically remove all commercials. Yes, I can edit the video/audio directly using the
    Panasonic recorder, but it is time consuming using small buttons on the remote control.
    I already know how to rip the video/audio from the DVD-R to the hard disk of my PC.
    What tools can I use to remove the commercials or unwanted material before I
    author a new DVD and burn it?
    Scenario 1:
    If the DVD-R has two shows (the second show follows the first), how can I split the
    video/audio to place the second show on its own DVD when burning time comes? The
    video/audio for the second show do not have its own set on files on the DVD-R.
    As an added bonus, how can I add a simple menu to display the name of the show?
    What if the DVR-R has two shows on it, but each show has its own video/audio set of files
    on the DVD-R? When you play the DVD on a home recorder you see two separate shows you can
    select from.
    Scenario 2:
    A DVD-RAM disc contains four separately recorded shows. When you play the DVD-RAM on a
    home recorder with DVD-RAM capability you see four separate shows you can select from.
    How would you create four different segments to edit, add a simple menu with the name of
    the show, re-author and burn the four shows to a single DVD-R? Or to its own DVD-R if it
    is easier.
    I have experimented a little with TMPGEnc Author. I can edit and add a menu for each show.
    I am not using chapters; however, when I play the DVD on a home player there is a small gap
    where I removed the commercials or the unwanted material. If I remove the commercials or
    unwanted material directly on the Panasonic home recorder before copying the show from the
    Panasonic hard disk to the DVD-R, there is no pause in the video/audio when playing the
    finalized DVD-R.
    Your expertise is greatly appreciated!
    Edwin
    please don't cross post. one topic is enough. use the general forum for topics that covers everything.
    Jul 2006
    My apologies from cross posting. It will not happen again.
    Thank you!
