Hi!
New to Macs, so go easy on me...
I have some .avi movies on my computer, but some play with no sound... Most of them works fine, but some don't! What should I do? No way to work this around?
Thanks in advance.
Quicktime may need to have additional components installed before you can play videos encoded with certain codecs. You may need to install one of the AC3 components for audio (sorry, I don't have a link handy, but MacUpdate and VersionTracker are good places to look (for any freeware/shareware Mac software, at that), or DivX/XVid for MP3 audio.
If you have VLC or mplayer installed, you can use them to get more information on the codecs the AVI uses... of course, you can also use them to play the AVI file without worrying about the Quicktime components, as VLC and mplayer use their own codecs and not the Quicktime architecture.
If cameras add ten pounds, why would people want to eat them? -
Make sure You have installed latest DivX [Universal binary - PPC/Intel], 3ViX, AC3 [PPC/Intel], A52 [PPC/Intel] and XviD QT component [PPC/Intel]...
As far as I know, AC3 is redundant with the A52 codecs (at least if you're using this), same thing for Divx and XIVD-Avi-importer (XVID support has been included since a long time in DIVX). I'm not sure it would be advised to install them all.Originally Posted by SERBIANJean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés -
I have all of them installed for quite some time...No problems at all..On both, PPC and Intel Mac(s)...
Choppy Video- Hard to watch in Quick Time
By RS4425 in forum MacReplies: 5Last Post: 1st Sep 2010, 16:03 -
converting Quick Time
By butterflies in forum Video ConversionReplies: 12Last Post: 4th Dec 2009, 09:36 -
Quick time reference (.mov) also readable with WMP?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2009, 12:37 -
Quick Time Pro Help
By Soccerman77 in forum Video ConversionReplies: 1Last Post: 14th Dec 2007, 11:38 -
Quick Time Failure, HELP
By jackboyko in forum ffmpegX general discussionReplies: 1Last Post: 25th May 2007, 14:41
