Hi, I used to use DVD shrink to shrink then burn my DVDs (with Nero integrated) but a couple of weeks ago I would get an error where it would shrink the files perfectly fine but never burn past 3%. Does anyone know why this would be? I defragged my HD and switched media but that hasn't helped.
Also, since my past method has failed, I have been trying new ways. When I use DVD Decrypter the files come out too big, and when I use Clone DVD the quality isn't that good. What would be the best method. I was thinking of using DVD Shrink to compress the files, but then what is a good program to burn them onto a DVD +-R? When I tried burning the shrinked files with Clone, it says it doesn't support those file types (Audio TS/Video TS). Thank you
Shrink with DVD Shrink and output an ISO and burn it with Imgburn or DVDDecrypter.
I use ImgBurn now for Shrink burns. ImgBurn 2 works also: http://forum.digital-digest.com/showthread.php?t=63869
But I don't know why the files would come out too big with Decrypter unless they were too big in the first place. If you use the method above, you can also reinstall Shrink, which may help fix the problem.
And welcome to our forums.
Burning with ImgBurn is fine, BUT...
unless you are using PgcEdit to ensure that your ISOs have 32k gap blocks between IFOs and BUPs, you may have problems in the future with what you are burning. Please take a look at
http://www.digital-digest.com/~blutach/pgcedit_guide/burning_with_pgcedit/burning_with...pgcedit_v2.htm
and scroll down the section called Technical Information Regarding
32K Gaps to see why this is important. This applies to ANYTHING you make with DVDShrink. -
All right, thanks for the info. I'll try it that way.
Does anyone know why I was having the problem/is it common?
Thanks for the welcome! -
Okay, I am still having a problem. How do I set DVD Shrink to create ISO files instead of what it normally creates (which won't be burnt onto a disc by ImgBurn)? Whenever I try to burn the files that DVD Decrypter turns into ISOs for me, they come out way too big (8gigs as compared to the 4 gig version that DVD Shrink gives me) Can DVD Shrink give me an ISO that will fit onto one disc?
This is really frustrating. -
Oh dear! DVDDecrypter does 1:1 rips - if the DVD you rip is 8 GB, the rip will be 8 GB
DVDShrink shrinks to whatever you tell it to (4.37 GB by default - snug fit for one DVD5)
Every time you hit that Backup button in DVDShrink, you get the option to Select Backup Target, where you essentially can: Burn with Nero, create ISO, create ISO and burn with DVDDecrypter, or output to DVD folders.
/Mats
Question about how to scan without image/OCR program
By jimdagys in forum ComputerReplies: 1Last Post: 9th Dec 2009, 23:33 -
Best Of The Best Program Question ??
By bludude in forum Blu-ray RippingReplies: 6Last Post: 11th Aug 2009, 21:25 -
Student TV Program Question
By richrider in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jul 2009, 09:16 -
Another question about best program
By Kurgan71 in forum Video ConversionReplies: 9Last Post: 3rd Aug 2008, 06:03 -
FAVC(program) Question.
By cowboysroy31 in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2007, 03:20
