hello all,
I'd like to copy .dat file fro vcd to harddrive but there is error message: "cannot copy dat file invalid MS Dos function"
Please how can i fix this error?
thanks in advance
tiger
Tiger,
Download and run ISOBuster. It has helped me retrieve lots of dat files which I could from discs which Explorer or the Command Prompt. -
Tiger,
Pardon the prior cutoff. What I meant to say is that it has allowed me to copy dat files which I normally could not copy using either Explorer or the Command Prompt.
Regards,
The Daywalker
How do I copy mp3 files off my harddrive to a DVD-R
By kschwi in forum AudioReplies: 3Last Post: 4th Jan 2010, 16:42 -
Ripping DVD To harddrive in one hq file
By videodirector in forum DVD RippingReplies: 10Last Post: 15th May 2009, 11:56 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 20:31 -
AVSEQ.DAT file -video cd can't copy and play
By desiboy1436 in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th Jul 2008, 11:43 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 23:06
