hi
I have decrypted a DVD using DVD decrypter , but when I try to burn a DVD using nero it says that not enough space on 4.7GB DVD. Can I shrink the DVD or is there any easy way to rip DVD and fit on one disc.thnx
Results 1 to 15 of 15
U have to shrink/compress whatever and the quality of the video will degrade. OR u may be able to rid of some materials u don't care about and just burn the "good stuff." Of course the later requires that u are familiar with an authoring tool.
Or buy double layer 8.5 gig blanks? -
Use DVDShrink to shrink your decrypted files to DVD-5 size.
I took the liberty of moving this thread to the correct forum too.
/Mats -
What mats.hogberg said.
The easiest way is DVD Shrink after ripping. You can compress the whole dvd or you can click the reauthor button and just drag over the main movie and odd's are you won't have to compress at all or very very little to get it on a dvdr.
I did not think nero recode is usually just activated with nero ? Before i thought you had to pay extra to activate it, i don't know about now, because DVD Shrink always gave better results so i have not used recode for years.Originally Posted by ultramarine -
Nero Recode 2 is bundled with Nero OEM. Don't like it though. No option to encode with maximum smoothness and the output file format is non-standard.Originally Posted by Noahtuck
My nero came with the dvd drive. I used the program some time ago. Don;t use it now. I read somewhere that the programmer is the one for dvd shrink..... is it?
Anyway, I still a fan of tmpgenc 3 xpress for this kind of work. Just point and click. I heard tmpgenc 4 is out. Is it any good? -
It was written by the same guy and shares many features but has been "nerofied" (for want of a better word). It is not nearly as intuitive to use and is intended to work with Nero's other software.Originally Posted by ultramarine
saramalik, in order to get the best quality out of a back-up. I suggest you get fimiliar with the concepts of:
More Space=Less Compression=BETTER Quality.
And
Less Space=More Compression=Lower quality.
When i back-up stuff i'm always sure to REMOVE ALL the excess fluff that can consume valueble space. Like extra unneeded language tracks, trailers, ads, and removing repeated intros/outros for episodeic series discs. Also downsizing extras you want to keep, so they don't take up too much disc-space.
All of which is VERY EASY to do and well worth the little extra time. Doing this can mean the difference of having to compress 4GBs, or only having to compress 1.5GBs instead.
Theres really no need for Dual-layer, DVD-5 backups can come out quite nice if done right. -
For the love of god don't use DVD Shrink for backing up to DVDR! Unless you prefer half-assed backups, that is. Use DVD Rebuilder by JDobbs. I use Cinema Craft Encoder with it, but if you don't want to aquire Cinema Craft Encoder, DVD Rebuilder is bundled with freeware encoders that are almost as good as CCE. Some even argue they are better! Once you are experienced in backing up DVDs, you will understand how inferior DVD Shrink truly is. Best of luck!
There's nothing wrong with DVD Shrink (use deep analysis and AEC max smooth), from a non-homemade DVD. You can still have loss from re-encoding (as opposed to DVD Shrink transcoding), it all depends on what encoder and bitrate is used.
CCE is about $2000, so it's not an option for most people. On the other hand, DVD Shrink is free.Want my help? Ask here! (not via PM!)
Heh what about DVD2One you guys?
After i'm done removing all excess junk. Like ads, trailors, extra langauge tracks, extra intros/outros, and or downsizing extras i want to keep-- for the least compression possible/highest quality.
I then do the final resize with DVD2One w/variable engine(I NEVER use constant compression engine). I'm sure there are better encoders out there but i'm satisfied with DVD2One, it puts out nice quality.
(Oh and i do all my previous editing stuff above, with a combination of DVDShrink and DVDRemakePro.) -
Can I fit 5.3 GB video on a 4.7 GB DVD?
By better life in forum Authoring (DVD)Replies: 13Last Post: 16th Nov 2008, 21:42 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 12:46 -
How to Fit five VOBs onto one DVD?
By DeEp34 in forum Newbie / General discussionsReplies: 10Last Post: 14th Jul 2007, 20:42 -
DVD fit on screen
By NHLroyrocks in forum Authoring (DVD)Replies: 6Last Post: 21st Jun 2007, 16:54 -
What Is The Best Way To Fit 2 Hours On A DVD?
By Anakin in forum Video ConversionReplies: 14Last Post: 4th Jun 2007, 12:52
