  1. Member geohei's Avatar
    May 2002
    Luxembourg
    Hi.
    Due to an Encore DVD restruction (long story), I need to patch the resolution of the built VOBs back from 720x576 to 704x576, using DVDPatcher.
    Do I also have to patch the VTS_xx_0.vob files?
    The movie is (afaik) only included in VTS_xx_1.vob upwards, correct?
    Thanks,
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    VTS_xx_0.vob are the menu files... So yes: VTS_xx_1.vob are the movies files.
  3. Member geohei's Avatar
    May 2002
    Luxembourg
    Ok. Thanks!
