Hello, i have some video clips and i will like to merge together. I try using
Movieshop Deluxe-Broderbund, but some how it crashes after a while. I will like
to use multiple layers, Movieshop has it but its just not working right.
Thanks!![]()
"Which program" depends on the format of the clips - some tools are better suited than others for different formats.
Use GSpot to find out the format(s) of the clips and post the details here.
In general:
Most types of AVI: VirtualDub
WMV files: Windows Movie Maker
I'm not sure about other formats (like MPG or MOV etc.) as I don't generally need to join clips.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
program
By maxone71 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2011, 05:23 -
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 12:04 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
which program?
By MONSTERTITO in forum Authoring (DVD)Replies: 1Last Post: 1st Oct 2008, 12:30 -
Does anyone know a program that does this?
By dcsos in forum AudioReplies: 6Last Post: 10th Jul 2007, 06:05
