so i got this darn thing a while back, this download manager - and now ive uninstalled the piece of crap tried deleting all traces.....but everytime i go to download somethin in IE the stupid program pops up by default
how can i rid this thing so it doesnt happen,heard it's got spyware or whatever the heck as well, could be the reason it keeps coming back
i want to download normally
http://www.google.com/search?hl=en&q=remove+flashget
Google is your friend
just a thought
mastersmurfie -
Put Flashget in manual mode only (when needed) and you'll be impressed how good it is. If you haven't found the time to read config basics - the manual... you'll have to bear consequences. With hi-speed cable and DSL there's less and less need for download managers. Flashget is one of the better ones and first one to have offered multiple connections with the same source...
I've used it for years ... and everytime I reinstall Windows XP or back when I used WINME ... I always made sure I had Flashget installed
I like Flashget ... works for me ... I also use GetRight. Getright comes in handy when a download is corrupted ... I then use Getright ... to get it ... right. -
ive got scan spyware it found entrys of flashget to delete, but i need the full app to asks for a key. what a bummer
i want to rid the damned thing lol,its done no good for meOriginally Posted by InXess
Maybe try a RE-INSTALL, go into it and disable the browser integration to remove the "link" to IE, then UNINSTALL it again
managed to get it out with Pest Patrol
but thanks for the replies folks 8)
Question about download managers like Flashget and Thunder/Xunlei
By jimdagys in forum ComputerReplies: 1Last Post: 21st Nov 2009, 19:27 -
measuring video annoyance
By ahidayat in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2009, 03:18 -
Vista hack for this annoyance...........
By SIRCOOKS in forum ComputerReplies: 4Last Post: 17th Mar 2009, 22:16 -
please explain different versions of Flashget
By jimdagys in forum Video Streaming DownloadingReplies: 2Last Post: 30th Mar 2008, 18:32 -
Annoyance with Hauppage Soft PVR
By DB83 in forum Capturing and VCRReplies: 3Last Post: 20th Dec 2007, 10:00
