I hope this is the right place to post this:
This question came up in one of the DVD distribution groups I'm a member of.
We have a single DVD currently in VOB (mpeg2?) format that we are planning to distribute. Members then make copies and forward the copies to other members.
Is there any reason to think that converting the DVD into DIVX format will confer any advantages in terms of dependability of the final result, e.g, ease of copying, likelihood of errors due to scratches or other physical damage (which I'm assuming is our major cause of re-sends) resulting in having to re-issue copies etc.?
My guess is it shouldn't make the slightest difference, since it's all error corrected DVD data in the end and in either case, in this example, everything will fit on a single DVD.
But doesn't the smaller size of DIVX imply that, for the same sized scratch on a DVD disk, potentially
more data would be obliterated using DIVX vs VOB, making recovery easier with the less compressed format?
On the other hand, since DIVX is more compact, isn't there more chance that a random scratch will be on a part of the disk which doesn't affect the material?
Comments anyone?
Cheers,
Losher
Divx usually also has longer GOPs -- typically set a a max of 300 frames. So a scratch in a Divx file can potentially have a much longer effect (as much as 10 seconds) than with MPEG2 DVD (typically 1/2 second).
vob/mpeg2 to Divx close to Dr Divx?
By Tiribulus in forum Video ConversionReplies: 8Last Post: 5th Dec 2009, 12:52 -
VOB Error With Avidemux
By Nitro89 in forum DVD RippingReplies: 50Last Post: 9th Mar 2009, 08:00 -
Dependability of low end OLD vcr's
By 389poncho in forum Newbie / General discussionsReplies: 13Last Post: 11th Dec 2008, 08:31 -
Recovery Divx Files
By nempo in forum ComputerReplies: 3Last Post: 30th Oct 2007, 12:08 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 22:44
