I have some video files that are actually saved into a .divx file. I want to at the very least convert them to an avi and then into an xvid avi. My problem is the only software I know that will do that is virtual dub and that would take forever (about 50 files) to do one at a time. Any ideas? Freeware is best.
Have you just tried rename the .divx to .avi? it usually works fine.
But why convert to xvid? -
No need to convert. As said renaming should work since the divx media format is an extension/hack of avi and is supposed to be fully backwards compatible. Simply remuxing with a tool such as VDub that doesn't support the divx extensions should give you a true avi and if you want XviD, just change the fourCC from DX50 to XVID.
If you need to rename a bunch of file extensions, something like this may work faster than doing them one at a time: http://sourceforge.net/projects/file-folder-ren
Easy tool to change audio fps
By davidbowie in forum AudioReplies: 20Last Post: 17th Jul 2014, 04:23 -
a good tool for converting avi or divx to the dvd vob format?
By extent in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2009, 13:37 -
Any easy tool to make a DVD photos slideshow with the background?
By coody in forum Authoring (DVD)Replies: 9Last Post: 27th Sep 2008, 14:34 -
Tool to detect avi/divx's for faults
By tfamok in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2008, 13:08 -
Looking for easy tool to get length of a DVD
By lcluster in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2008, 19:01
